H41DS Fluorescent fixture replacement
Mar 16, 2021
92
hunter 41 DS tacoma
Anybody know a source for light fixture to replace the fixtures (see pic)? I don’t care what type, as long as it fits.
This website apparently deletes any posts in which I criticize a product (great sailor solidarity) so I’ll just say that there is a small fuse soldered into the circuit board (that’s right, a soldered fuse) and the only way to professionally replace it is by removing the rivets on the back & melting the solder. Then, of course, either soldering a new tiny glass fuse or jumping the gap. So planned obsole*cence.
10,093
Welcome.. Looks like two 1 foot long cut strips from the 16 foot long strip will give around 220 lumens per foot and should be plenty bright.
Sep 11, 2011
426
Hunter 41AC Bayfield WI, Lake Superior
You can also buy bulbs that have LED,s installed. Just like the strip lights, bypass the ballast. Direct wire.
