H41DS black foam boxes in ceiling?
Mar 16, 2021
93
hunter 41 DS tacoma
What are these black foam boxes that foil my attempts to remove the hard plastic headliners to access my leaky deck fittings? I see no screws -are they glued in place?
JamesG161
Feb 14, 2014
7,936
Hunter 430 Waveland, MS
In my discussion, with Experts from Hunter, my guess is Yes, on glued.
They used probably, fast drying glue, as they did assembly line production.
Jim...
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
Whereabouts on the boat are these?
Mar 16, 2021
93
hunter 41 DS tacoma
I haven’t been through the whole lid yet. But, so far I found them starboard in the aft cabin (directly above the space behind the headboard) and the pic I posted is looking back at the forward bulkhead, port side.
Mar 16, 2021
93
hunter 41 DS tacoma
I should’ve noted that they are both foam with a rigid core. The aft cabin version actually spans between the mini bulkhead by the bed and the bulkheadish wall forward of the bed (shared with the head). So, that one isn’t attached to the deck and presents like a shelf. A wire loom or two runs along the top of it.
