H41 power routing solar panel help
Feb 10, 2017
305
Hunter 41 Progreso
I need to connect my solar panel array with my mppt that will be located under the chart table, how can reach this location with my cable?
i manage to go under the rear cabin but from there how i reach the chart table.?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Consider running cable through or adjacent to existing wall chases where cables between the navigation station and cockpit helm are routed. Probably requires a method to fish the cable.
senang
Oct 21, 2009
318
hunter 38 Monaco
My answer is for our 2005 H38, but layout is mostly similar by manufacturers. Under the port hanging locker there is a tube with cables from the rear end of the boat, running from there to under the seat at the nav station.
There is another tube holding cabling that runs also on port, it is at the height of the joint between hull and deck. It starts further back under the ceiling in the aft stateroom and finishes behind just in front of the vanity bulkhead. It is more hidden on the nav station side and getting to it on that side is not easy.
