H41 losing coolant somewhere
Mar 16, 2021
93
hunter 41 DS tacoma
2008 H41DS with 4JH4E. Some tiny amount of coolant disappears without a trace. Never goes over 175 deg under way, but every 5-6 hours about 4oz lower in the reservoir. Already tightened every obvious connection, including the water heater loop. No puddles, no vapors, NADA! Where is my coolant going?
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
Nach, I had the same issue for awhile. I found one of the coolant drains in the rear of the engine had loosened a bit and was cracked open. never had a puddle or anything but the slightest of leaks. Also I have found a known problem with the coolant filler nozzle attachment to the top of the engine had a small leak. That one has been more persistent and difficult to repair. One other item you did not mention is how does your exhaust look? Does it have lots of white smoke. Is there stuff on the hull where the exhaust comes out. Both of these might indicate a leak into the engine. Good luck!
Likes: Nachismo
dmax
Jul 29, 2018
1,257
Telstar 28 Buzzards Bay
Along with checking out the exhaust, look at your oil to make sure it's not contaminated with anti-freeze (will get milky).
Likes: Nodak7
Mar 16, 2021
93
hunter 41 DS tacoma
Nodak7 nailed it! A tiny crank of the aft drain valve & no more disappearing coolant! THANKS!
Likes: Nodak7
senang
Oct 21, 2009
316
hunter 38 Monaco
Just for the record of possible leaks of cooling water don’t forget the hot water tank heated by the engine coolant!
Likes: splax
splax
Nov 12, 2012
694
Hunter 34 Portsmouth
on the 34 the water heater hose wears on the hull ribs. check the bilge for coolant
