Last year I noticed that the aft port corner of my organizer cover was soft. I have the later version organizer cover that is in two pieces. And I also had a rain leak into the area over my dinette light. Knowing that the four corner screws that hold the organizer are suspects for the leak, I pulled off the cover this Spring.
I found that the organizer had a crack along the aft edge and that was likely to be the reason for the softness. I taped over the four hold-down screws and hosed the area- no water leaks. So I know that one of the hold down screws is the culprit for my leak.
I brought home my organizer cover and I thought that I would just have to open up the crack and fill it with thickened West System epoxy. Now the fun began......
A cut into the bottom edge showed that the wood core was saturated with water. So I made some test holes to see how far the water has gone. Long story short, the wood was saturated from the aft edge up to 10" from the forward end. I could push on the wood and water would squish out! So after cutting out the bottom fiberglass covering I used a vibrating multi-tool to cut underneath each of the wood blocks. I will repair this cover with new wood blocks and West System epoxy. Around each of the screw holes I will fill with epoxy so that water cannot get into the wood core from the holes. I will cover the wood blocks with fiberglass cloth and more epoxy.
Does anyone here have any tips for me?
