Tayana v. Hunter
It never surprises me the quality of the overall advice and/or observations folks post on this thing, Mark.First, run down and buy yourself a copy of the Jan. 2002 Cruising World magazine and read Nim Marsh's article beginning on Page 88 about the Tayana 37. It's a good article and brings up some good points. Also, get in touch with Bob Perry; yes, he's still alive and well and for $350 he will open his files to you on all the boats he's designed over the years and personally consult with you about the strengths and weaknesses. Perry's a very astute and honest fellow and, in this case, he'll be "working" for you. His insights can be very helpful.Over the years, I've worked on a few Tayanas and I personally like them. Most of the machinery is in reasonably easy access and you generally don't have to be a contortnist to work on systems. Listen, the Chinese were building blue water boats while our ancestors were scribbling on cave walls, so I think they know a few things about ocean-safe boats. However, there is something to be said about the QC/QA in the early years and the advice you were given about eschewing the early models is sound. You don't want wooden spars, either. Most of the ones that had wooden spars have been modified with aluminum installed. Also, just so you know, there are 900 bungs and screws holding the teak decks down. I tell you this in case you have deck leaks..and some of the older ones do. Welcome to "Recalk your decks 101" and it's an arduous task. Also, chances are good you will have to remove and rebed the ports on older models, i.e., anything 10 years or older. More hassle than anything, but you don't want leaky ports. Ditto on the hatches. Most of the Tayanas available out there today in the $65k-$95k bracket typically suffer from lack of attention, so a good survey is mandatory.As to your question about whether a Hunter or a Tayana makes a better cruiser, well, in my opinion, the Tayana wins hands down and I own a 78h30. I can't speak to the successes or failures others have had and I freely admit I really like my Hunter for daysailing, coastal cruising and that sort of thing, but I don't consider either mine or any other Hunter to be what I would necessarily call a true bluewater cruiser. Others will disagree with me, but I have been on a variety of true bluewater yachts over the more than 35 years I've been doing this and I can tell you none of them were Hunters. All this talk about comfort over speed is hogwash; want to go fast? Well, then, why the heck are you trying to go anywhere on a boat then? If you have the need for speed, go by jet. In any bluewater endeavor, most of us -- the racing elite not included here -- want the comfort and security of a sea-kindly boat and I think that pretty much is what Tayanas are all about.I think, too, from what I have seen over the years that a $65k Tayana is going to require a bit more work while the ones on the upper end usually have most of the stuff done on them already.Of course, that's just my opinion and sometimes it's only worth what you pay for it!
