I want to repack the H 356 shaft stuffing box with the newer GTU Gore packing.Anybody know what size to use.
Thanks
Thanks
Thanks
I also use the newer stuff. But I do not worry about the size... I just us the thinest thickness size I believe its about 1/16 th maybe less then an 1/8 th inch can't remember. I just start wrapping and feeding the packing into the stuffing box till I can just get the threads of the nut to catch..... Then I tighten hand tight.... Run the prop a little then tighten a little more to just stop any leaks while it's at rest. Check it every once in while to make sure shaft is not getting hot.... Sometimes it drips a little when running sometimes not. If it starts to drip to much I just give the nut a little extra turn to stop the leak at the dock ..... After a few years or so.... When I start to run out of thread I just back off the nut and add a little more.sailmaster39 said:I want to repack the H 356 shaft stuffing box with the newer GTU Gore packing.Anybody know what size to use.
Thanks
Yep! K.I.S.S. A big believer.ONECOOLAIR,
So you never pick out the old stuff, you just keep adding new, and that works?
Buck Algonquin Bronze Packing Boxes are usually the following sizes and take the following packing size:I want to repack the H 356 shaft stuffing box with the newer GTU Gore packing.Anybody know what size to use.
Thanks
