H356 shaft packing size
116
Hunter H 240 rehoboth beach , De
I want to repack the H 356 shaft stuffing box with the newer GTU Gore packing.Anybody know what size to use.
Thanks
Dec 2, 1999
15,184
3/16" packing for a 1" shaft. I don't know if anything has changed but that was the standard.
Be sure to cut the ends at 45 degrees or so and offset the ring cuts.
Mar 20, 2004
1,746
Steve's correct-it's 3/16". The Gore works really well, just installed it again on Escape last year
May 29, 2011
116
Thanks so much,you guys are the greatest and so is this Hunter owners web site.
One more question...........I just installed the lewmar folding wheel.I have the Ray st 4000 auto pilot.The wheel will not latch onto the protruding rod from the pedestal to engage the st 4000.any solutions for that issue.
richard
Thanks
Jun 25, 2012
942
hunter 356 Kemah,the Republic of Texas
Thanks
I also use the newer stuff. But I do not worry about the size... I just us the thinest thickness size I believe its about 1/16 th maybe less then an 1/8 th inch can't remember. I just start wrapping and feeding the packing into the stuffing box till I can just get the threads of the nut to catch..... Then I tighten hand tight.... Run the prop a little then tighten a little more to just stop any leaks while it's at rest. Check it every once in while to make sure shaft is not getting hot.... Sometimes it drips a little when running sometimes not. If it starts to drip to much I just give the nut a little extra turn to stop the leak at the dock ..... After a few years or so.... When I start to run out of thread I just back off the nut and add a little more.
Pretty simple really no hassles.... Frankly I have never understood why people keep having so much trouble and making such a big deal about this shaft stuffing box thing it's really quite simple!
Dec 4, 2003
90
Hunter 356 sandusky ohio
ONECOOLAIR,
So you never pick out the old stuff, you just keep adding new, and that works?
Mar 20, 2004
1,746
That's strange-I did exactly the same thing and the 4000 engages the post just fine. Make sure the wheel and pilot are on all the way. I don't think they make a dished wheel-mine's flat. If it only misses by a little, you could shim out the rod at the pedastel end-or order a new rod - it's cut to length at install
Jan 26, 2009
100
HUNTER 340 Raritan Yacht Club
Packing Gland Shaft Size = Packing Size
Thanks
Buck Algonquin Bronze Packing Boxes are usually the following sizes and take the following packing size:
Shaft Size Packing Size
3/4" 3/8"
7/8" 5/16"
1" 1/4"
1 1/8" 3/16"
1 1/4" 1/4"
1 3/8" 5/16"
1 1/2" 1/4"
1 3/4" 1/2"
2" 3/8"
This site will show you the same above info and more but is slow loading up.
http://www.emarineinc.com/categories/Packing%2dShaft/
This site will give you a pictorial step by step guide on replacing a packing gland
http://www.pbase.com/mainecruising/stuffing_box&page=1
I used it to do mine for the 1st time and it was flawless.
Please let me know if this info helped you
Regards
Bill
