incorrect path
You're right, our boat is less than 6 months old. As you probably know, the line is secured to a pin at the top of the rudder post. It then runs down, around a block and back up. At this point is is supposed to go around the pin again and out to the tie off point. Well, ours didn't go around the pin and was rubbing against the side of the rudder post which is rather sharp. Last week I noticed it was sawed halfway through at that point. Don't go to any trouble to measure it, I can do that when we get back out to the lake. I just thought someone might know.
