H34 Sliding Hatch/Crib Board Cover
Dec 7, 2016
66
Beneteau Oceanis 45 Annapolis
One of the few projects I'm not even going to attempt to take on this winter during my 85 H34 partial refit is replacing the cracked sliding hatch cover. It appears I would have to remove the entire sea hood to replace it. The P.O. fashioned a bit of a poor man's dodger/boom tent/hatch cover made of sunbrella and some bungees that's downright ugly, must be taken down before sailing and restricts access through the companionway when in use. I'm assuming he made this contraption to keep water from getting in through the sliding hatch which I hear is a problem even if there isn't a big crack running through it. While I have the sewing machine out recovering the boat cushions I was thinking of making a set of covers for the hatch and newly refinished crib boards. Wondering if anyone else has done something similar or if they have implemented another solution?
Nov 26, 2012
1,654
C&C 40-2 Berkeley
I have done this. You do not have to remove the entire sea hood. It is actually not that difficult. Remove the screws that hold down the seahood that run along each side of the sliding hatch and carefully pry up the seahood on ether side. Once free of the sealant it is flexible enough to lift up and allow you to slide in a new hatch. Clean the old sealant out of the joint and reseal. Do not forget to seal the screws as well. The track on either side of the hatch captures water and channels it to the cockpit. On the forward edge, however, there does not appear to be any such channel. Water that runs off the forward edge of the hatch was making its way into my galley. So, using a Dremel routing tool I cut a 1/4" deep by 1/2" wide groove all the way across the hatch. This groove is hidden under the seahood at the forward end of the hatch. Water that flows forward now goes into the groove and laterally to the channels. My galley stays dry as a bone in the rain now. I had the hatch made at Tap Plastics.
Likes: Mike Kegley
Nov 6, 2006
10,256
I have the new slider and handles made up but have not put in in yet. I had the seahood off 12 or so years back, looking for a drain at the forward end, but no such drain existed.. I drilled a lateral hole at each end of the front of the slider track, but it really didn't help mine drain..The holes are too high vertically.. going to try to correct that when I open it the next time.. Of note, the traveler track is held to the boat on the ends.. if you take out the 4 (IIRC) bolts at the traveler track ends, you can use the mainsheet to help lift the hood.. careful not to stress it a lot because the gel coat will crack easily.. Take lots of pictures !
Dec 7, 2016
66
Thanks for the tips. Doesn't sound that bad after all. I have to go to the local marine plastics place to get some new fixed portlights made so I might as well have them make a new hatch at the same time. The Gorilla tape holding the current one together is pretty unsightly
Sep 4, 2007
795
Hunter 33.5 Elbow, Saskatchwen, Can.
You can make a cover for over the companion way. It will help keep the rain out when you're not on board.
