Scott Donovan
I have discovered that there are two areas where the fiberglass has separated/cracked away from the forward edge of the aluminum hatch plate (Salon Hatch)and fiberglass hatch box. The gap on the leading edge is about 1/4".They appear to be stress related issues.In both cases the gap can be closed with hand pressure. I'm contemplating using West System epoxy, clamping until cured.If anyone has had similar problems, I would appreciate a response as to how you corrected it.Scott
