That is one of the old style Bomar hatch supports. if you have the other piece, take the rod to a good machine shop and they can weld it and grind it back down so everything fits. Remember to close the hatch before tacking or gybing ;~)
The options are limited for the Bomar Riser Arm P100-02 (right or left) as I have only found the complete assembly and not the inner part. I've got a couple that are bent and probably going to break as well. I've straightened them a couple of times and they are looking pretty fatigued. But I only need the interior part as the knob and tube are still fine. If you search the web you can find a number of suppliers from $50-$80.
The Hunter Owners Store has a couple of options that may work for you under Hatch Arms and Adjusters. Some adapting might be necessary.
Of course from the Search Owners tab, there are 3 H34 boats in Toronto that might be nearby to you. (not recommended) :naughty:
I had touble figuring out the exact arm for the P100 Cast Hatch so I called Bomar/Pompanette and the rep on the phone walked me through it and got me the correct arm. It was the whole assembally including the bolts. It was about $80.
