Peggy wrote "Why would you limit toilet use to urine only? Would you do that at home? It doesn't make a bit of difference in the holding tank, nor to the hoses when it comes to odor elimination...nor does it matter in the tank whether the toilet is flushed with salt water or fresh."
Peggy,
I'm sorry but I have to agree with Dan. Ours is for the most part urine only as well. I say for the most part because there have been times when getting to the on shore head was next to impossible so the head on the boat was used. But in no case is there ever toilet paper used in the head. There is a trash container, lined with a plastic bag, under the sink that is emptied daily if needed. TP sooner or later clogs vents plain and simple. Also both heads are freshwater flushed due to the oder of the sea water if left in the head for any length of time. The water in our marina is very dark in color with low salt and high tannin. It has an oder sometime.
Here are the instructions given to everyone that comes aboard. They are also posted in the head.
INSTRUCTIONS ON THE USE OF THE HEAD
1. THE ONLY THINGS THAT GO INTO THIS HEAD MUST HAVE GONE INTO YOUR MOUTH, THROUGH YOUR BODY AND THEN INTO THE HEAD.
THERE ARE NO EXCEPTIONS TO THIS RULE
2. ALL PAPER PRODUCTS ARE TO BE PLACED IN THE TRASH CAN UNDER THE SINK. YES THIS INCLUDES USED TOLIET TISSUES.
THERE ARE NO EXCEPTIONS TO THIS RULE AS WELL.
3. TO FLUSH, SIMPLY TAKE THE FIXTURE FROM THE SINK TO THE BOWL, TURN ON THE COLD WATER, NOW PUMP THE HANDLE UP AND DOWN UNTIL THE BOWL IS DRY, CONTINUE TO ADD SOME WATER AFTER PUMPING IS STOPPED. REPLACE THE FIXTURE AND SHUT OFF THE WATER.
4. CLOSE THE LID
NOW THAT WASN’T HARD WAS IT?
THANKS
Capt. VINNY
