Hello,
My quandary about the old diesel fuel in the tank ended as I resigned to dump some more additive in the tank and hope for the best. Since it is 25 gallons of fuel about four years old and the PO had put additive in every year, hopefully the new fuel filters will catch the gunk.
I had tried pumping it out with a drill attached pump, but it didn't work well. The gallon I pumped from the bottom of the tank looked OK and had little debris. I have been advised to run the tank mostly empty and remove the tank to clean it instead of cutting an access in the tank. Has anyone removed the tank from a H34 ? How much needs to be done to get the tank out ? I don't think it will fit through the seat opening, so removong the aft berth bulkhead seems to be the only way.
