V
Vinny Johar
I've just inspected the forward face of the compression post in a Hunter 34 I'm looking to purchase, and it was in fine shape. However, when I removed the teak just forward of the compression post, I found that the headliner had pushed down over the top of the teak piece which had put about a 1/8" dent in the headliner. I see the compression post is OK, but I'm a little worried about the beam (which is hidden by the headliner) that sits between the mast and the compression post. Is there a way, other then taking out the that bulkhead and things around it, to get a look at that beam? Could I drill through the headliner somewhere and get an idea quickly as to whether or not that beam has rotted? I would greatly appreciate any comments or suggestions on this. Thanks.
