I've noticed that my 3GM30F is making a lot of noise when it idles. I asked my mechanic to take a listen and he thinks there may be air in the fuel. BTW, it runs like a fine tuned engine at high RPM's. So I began my research and found the following regarding modern diesels.
It is important that the fuel return line is sloped down to the tank with no traps or obstructions in the line. If this is not done, the fuel system is prone to air-lock with consequent hard-starting.
On my H34 the return fuel line drops down from the engine and is fed through the small hole into the dungeon after which it rises to fuel tank. This begs the at least 2 questions. 1) How many have the same fuel return line layout and 2) Have you had any such described problems?
Any thoughts?
Any thoughts?
