Wiring is critical
I agree with Chuck, call Hunter. You might also look at the docs that came with the boat because you might well find that the wiring for the windlass is already installed, but not connected, in the wiring bundle in the boat.It is important to wire it properly with a breaker and cut-out and to have the switches control it though a relay etc. So the standard Hunter installation would obviously have all that implemented.I have the standard windlass - as per Micheal Stacy's post - on my 33. It has two problems. First, you must keep it very clean to ensure that the clutch will properly disengage. Otherwise you will find yourself having to power the anchor DOWN! Fortunatley disassembly of the above-deck parts is easy.Second, the position of the windlass in relation to the anchor locker means that when weighing the anchor chain it almost always jams. This is because the windlass is at the top of a short slope before the chain drops vertically into the locker. There is not enough wieght of chain pulling on the exit from the windlass to keep it straight and clear. I find that I need to have one hand on the deck switch and bend over to use the other hand to pull chain clear of the windlass every ten seconds or so. This is actually a bit dangerous, especially if it is blowing.I wonder if any one has come up with a solution for that one - short of rebuilding the anchor locker and taking up some headroom from the front of the V-berth!
