H310 port side ropr clutch
Jul 2, 2019
102
Hunter 310 Pine Beach, NJ
On the starboard side there’s an access panel in the cabin that you can get to the fastening nuts. There’s nothing on the port side for the double clutch. I need to replace all of mine and would like to use one with a different bolt centers. Did Hunter just use wood screws on the port side and attach the clutch to the fiberglass deck?
Jan 7, 2011
6,017
Oday 322 East Chicago, IN
I doubt that they just used wood screws to secure it into fiberglass. If there are no nuts underneath (so not throug-bolted), there may be an aluminum plate embedded in the fiberglass, and tapped and threaded, so machine Screws or something similar are screwed into the aluminum plate. Like a backing plate, but not visible.
easiest way to know is to take one screw out and see what it is.
Greg
Apr 11, 2021
14
Hunter 310 Island Heights, NJ
We replaced the clutch last year - we were pleasantly surprised to find an aluminum plate. It was tapped for the exsiting holes. We added a triple clutch and tapped a third set of holes. Turned out to be an easy project, much to our surprise and delight.
…Rick
Jul 2, 2019
102
…Rick
Small world. Hi Rick. I'm the guy across the river who just msg'd you. It looks like the clutch pad molded into the deck on the port side is designed for a triple. There is room to the left of the existing double. Can I change to a triple just by D&T left of the existing holes? The alum plate extends toward the left? Oh BTW if your coupling can be cured by honing, I may be able to help get that done. Work at a plant with a complete machine shop in Lakewood.
Apr 11, 2021
14
We found a triple on Ebay - new. Lined up the 4 existing holes, then marked, drilled and tapped the 3 set. We replaced the port side, and plate extended to port.
Will let you know if we get desperate on the coupling. Really hoping not to pull the engine.
