Does anyone know where the AC raw water pump is plugged in or connected to power. I may have a problem with my AC raw water pump or the controls to it from the AC unit itself. So I want to plug it direct to 110v power instead of via the AC unit and see if it runs on it's own. But I cannot find where the cords is run. The pump is located under the main berth, starboard side and the power cord goes into the wall aft of the refrigerator. But i couldn't easily access anything in that wall but assume it must run somewhere where you can disconnect it to replace the unit.
