H31 rudder
Jan 11, 2004
65
Hunter 31_83-87 Middle River, MD
A marine surveyor suggested that the rudder on our 1986 Hunter 31 is in bad shape. How would I know if this is the case, since the rudder looks perfectly fine as it always has. Can anyone shed some light on this? What would I look for to determine if the rudder is in poor condition?
Jan 7, 2011
6,017
Oday 322 East Chicago, IN
Usually it would indicate that there is water in the rudder, delamination of the fiberglass, corrosion of the stainless internal frame, and degradation of the foam....all of which compromise the integrity of your rudder.
But maybe you should ask the surveyor specifically what he found and what it means.
Greg
Likes: sail sfbay
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Ditto Tally Ho and David in Sandusky.......when my 1987 Hunter 31 was surveyed in 2009 the surveyor said the rudder had water contamination. I immediately had the boat yard manager access it and we agreed it might or might not but just go ahead and sail it anyway and the risk of failure was low. That is what I did. But like the others advised, ask the surveyor to explain his findings and recommendation(s).
Jan 11, 2004
65
Thanks, all. I did not hire the surveyor. He was hired by a prospective buyer. I also think the risk of rudder failure is low, and I intend to launch and sail the boat as soon as possible.
HMT2
Mar 20, 2014
900
Hunter 31 828 Shoreacres, TX
I had a friend that lost his rudder on an ‘84 I have PM him about this thread to see if he has any wisdom to impart.
Mar 20, 2011
624
Hunter 31_83-87 New Orleans
Yep, lost rudder to a collision with something floating below the surface while racing in Galveston bay . Broke off at welded joint. Not sure what the surveyor is seeing as far as evidence of failure. Was the rudder leaking water when it was hauled? Any rust or discoloration around post? I think he has some explaining to do especially if this will affect the sale of the boat. FYI. Foss Foam pricing on a replacement rudder For our boat is about $2200 not including yard charges
