H31 jib sheet cleats
Feb 6, 2013
437
Hunter 31 Deale, MD
The H31's have sail-tailing jib sheet winches, but they also have cleats to secure the sheets. Has anyone ever used these cleats for this purpose?
Thanks.
Oct 30, 2011
542
klidescope 30t norfolk
If it's an older h31 circa 80' then it probably predates the self tailers so the cleats just live on with no purpose. Remove; repurpuse maybe a mid ship cleat
Nov 26, 2014
51
HUNTER h31 Northport L.I.
I don't think I have ever had a line on those cleats, but a midship cleat surely would be a good addition!!!
Reg M
May 21, 2016
131
Hunter 31 Montague
Every sailboat I have owned with self tailing winches also had the cleats and I have always used them. I may be way off base but here is my way of thinking as to why I use them. Those self tailing winches are very expensive critters and when you leave your jib sheets jammed into the self tailers you are keeping the springs under pressure and perhaps shortening the life of the springs. I guess the replacement springs are probably not that expensive but if I don't have to replace them, what the heck? At any rate, after over 40 years its a habit I probably won't be breaking soon and I have never had a jib sheet come accidently undone.
Dec 28, 2014
61
Hunter 280 Mandeville, LA
Actually the springs only activate the palls which then engage and carry the full load as they get pushed back into their seats.
Jun 28, 2005
440
Hunter H33 2004 Mumford Cove,CT & Block Island
On our boat (H33) we only have 2 cockpit winches. so the jib sheets run through the jam cleats, and then to winch. it allows us to use the winch for another line e.g. furling main (reefing). If we had aft winches dedicated to Jib sheets, we wouldn't need them, so it depends on how your boat is set up i.e., 2 or 4 winches.
