H31 Fiddle Block
Feb 22, 2004
222
Hunter H340 Michigan City
Can someone tell what size line is on the main sheet traveler that runs around the fiddle block on a 84 H31. Not the blue line but the white line . My boat is in storage and shrinkwraped and I want to get a new fiddle block ordered. Also if you know the diameter of the top sheave it would be very helpful.
Thank you much
Keith
2,191
Keith...
I would suspect that it is probably a 7/16" line, which is the same size I use on my H34.
As for the block size, I use Schaeffer 700 series blocks for sheets and halyard controls. 7/16" line should run through them easily without over stressing them.
Jan 11, 2004
65
Hunter 31_83-87 Middle River, MD
As noted many times on this site, Garhauer makes great blocks and hardware at great prices (significantly less expensive than Harken & Schaeffer). Replaced all the original blocks on our '86 H31 several years ago.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
my guess is it is 3/8 i have a 30 ft er and the specs call for 3/8 and that block in the pic is a Schrieffer block for sure
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
Aren't the sheaves on those blocks replaceable?
