Don - Advice on Fixed Ports
You might want to search the archives and consider replacing the fixed ports. There were several posts a while back that included info on this. As yours are the plastic frame type a replacement might be a better solution.On our 83-H34 the frames were metal. The job took several weekends to complete. I had a local company in Atlanta cut me some 1/4'' tinted lexan to approximate size. I removed the frames completely which turned out to be more difficult due to 2 of them being re-sealed by a previous owner. Application of 3M adhesive remover helped a little. Once out I repaired some minor core damage using a 2 part epoxy and marine-tex for fill. I also overbored the screw holes, sealed with epoxy and filled with marine-tex. This was the bulk of the on-board work.I had taken the frames home, removed the old lexan, and peeled, scraped, and sanded them down. Before re-painting I test-fitted the new lexan. Trimmed using a jigsaw (pvc pipe blade) and dremmel. Prepped and re-painted the frames.Back on board I re-fitted the frames, sealing with dow795 white, screwed in place. Then I sealed in the lexan windows using dow795 black.Overall result was fantastic. Much more work than initially anticipated, but thats how most boat projects go. I do have some photos and once I get some of these Y2K projects on track I'll scan them and send to Phil for posting.Good Luck.Scott.83-H34 Island Hops
