H306 Aft Cabin Leakage
Aug 20, 2013
38
Hunter 306 Deale, MD
Good morning!
So, while checking on Bedouin while she's on the hard I noticed some leakage in the aft cabin. Seems to have seeped along the cabin wall under the aft port-side overhead panel. And there was also some that seemed to have originated just starboard-of-center behind the aft cabin partition. Not much - it's not like the cabin flooded. But enough to make the mattress pretty wet, resulting in a manic mold/mildew removal campaign. The water puddles appeared a bit rust-brown and not clear, by the way.
Anyway, I removed the overhead panel, managed to stick my head through, and shone a light around, but everything seemed dry. Examining the upper side of the panel (the side which would be hidden from view when installed) I noticed what appeared to be dried rust-brownish spatter that looked like the water must have dripped directly from above before seeping past the panel cover. The only thing I see right above the panel, though, is the port-side mount of the arch. The bolts didn't feel wet, but I'm still a bit suspicious.
I have read other posts where folks with similar boats have had leakage via the wiring from the binnacle where it comes through the cockpit flooring. But I'm wondering if anybody else has has a similar leakage issue on a 306 and has wisdom to impart?
I apologize for the rambling post, but it's a bit hard to describe without seeing it. Thanks in advance for any pointers!
Nick
Sep 3, 2012
195
Hunter 285 Grand Rivers Ky
It might be interesting to look at that brownish moisture on a slide under a microscope and determine if it is rusty water from something rusting or some sort of mold that is rust colored.
Oct 30, 2011
542
klidescope 30t norfolk
Sometimes on the hard the boat can sit at a strange angle or lean and leek fluids trapped in liner or leek at the hatch do to funny lean
Aug 20, 2013
38
@sailor Jeff - good point. I think I'll appropriate my daughter's microscope this weekend to find out.
@whatfiero - Also a good point. The boat is blocked bow-up by a few degrees to allow for rain and melted ice water to drain.
I have a guy coming out to the boat today to have a look. Hopefully it's not catastrophic...
Catalina 34 Casco Bay
is it possible that a bilge line has water in it, froze and split. subsequent warm day with melting could free up that water....and you know what color bilge water is...
