H30 Yanmar 2GM RPM question
1,283
Ericson 26-2 San Pedro, CA
It's the tach !!!
I first checked the linkage (took about a minute) .... nope, linkage fine. Bought a handheld tach at Harbor Freight and bingo ..... the onboard boat tach reports/reads exactly half of the actual engine rpm.
With the engine running at 2000 rpm (as measured by the handheld tach) the onboard boat tach shows only 1000 rpm. It's the same for every throttle setting - regardless whether I'm in neutral or in gear - the onboard boat tach shows exactly half of the actual engine rpm.
At full throttle I get 3500 (as measured by the handheld tach - 1750 on the boat tach).......
So.....now on to troubleshoot the onboard tach.......thoughts?
I have the workshop manual for the 1GM/2GM and it contains step-by-step instructions for troubleshooting both the sensor and the gauge. Private message me and I'll get it to you by e-mail attachment.
You'll also want to make sure that the tach you have is the correct one for your engine. It could be that a previous owner swapped out tachs and Yanmar tachs are not all interchangeable for different Yanmar engine models.
Jun 3, 2004
71
Hunter 290 Tampa, FL
(Bump!) I'm having the same issue...
Malyea, did you ever figure out why the tach is only showing half the actual RPM?
Thanks,
--Jon
malyea
Dec 15, 2009
236
'87 Irwin 43 Sea Breeze
Thanks,
--Jon
No, haven't yet got around to troubleshooting the issue...other than now knowing (happily) that the engine does develop full rpm at full throttle - although the tach reads exactly half actual rpm...
Jan 4, 2007
406
Hunter 30 Centerport
2GM RPMs
I had the same issue withholds 2 GM. Teach was reading about 1,100 RPMs. Clean mixing elbow, clean fuel and filters, replaced injectors with no change. I finally bought a laser tachometer on eBay for less than $20. You attach a reflector to the drive Lilly on the front of the motor. Within 3 minutes I had my answer. The real RPM at full throttle was 3,550 RPM. Either the tack on the panel, the sensor prone of the wires is bad. For now I know that the tach reads 50% actual.
