H30 Rudder repair
57
Hunter 30 Massena, NY
I notice a small leak at the bottom of our H30's rudder when she went on the hard last fall, I wonder if there's a way to check the internal integrity and see if the rudder is dry enough to repaire the small hole I found? Any help is appreciated
The consensus is to put a hole in the top and keep the hole at the bottom opened and let the water drain out. Usually only destructive testing will tell you if the metal holding the rudder onto the shaft is compromised.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
While Stu is, of course, right in that only destructive testing will tell you the condition of the metal framework inside your rudder, if you are not getting a "lot" of water coming out the hole, and if you are not getting rust stains at the hole, the innards of your rudder may be ok. While it is not scientific in any sense of that term, I would also tap all over the rudder with the plastic end of a screw driver or phenolic hammer to see if you can identify and perhaps isolate any "dead" spots in the rudder. You'll know it when you hear it. Depending on rudder type, if you find dead spots, you can drill a pattern of 3/8" holes (well described in the West System brochures and manuals) and inject liquid epoxy into them. And as for the leak hole itself, that can be repaired with common marine epoxy putty, which can be applied to a wet surface, if need be. IMHO, most all rudders of aging boats have some water in them. Once drained and holes filled, the rudder should be good to go. Good luck with this.
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
It's a bit of concern for sure. On one hand, it may be possible to drain it, let it dry, and epoxy repair it. It's impossible to know if the steel skeleton has been compromised by electrolysis however; is your boat in saltwater? Do you have any pitting on the prop shaft or rudder shaft?
Sep 25, 2012
57
The boat has always been in fresh water, the St. Lawrence and Lake Champlain, and the prop shaft looks great, I'm hoping for just a leaking problem, thanks to all for the info.
Ron
