h28.5 mast mainsail slide cover
1
Hunter 28.5 Solomons Island
I recently bought a 1988 h28.5. While removing the mainsail, I noticed that the plastic piece that covered the hole in the mast for the mainsail slides was broken. What is this piece called and can it be replaced? If so, do you know where one can be found / purchased? It looks as though it was originally riveted on.
Dec 2, 1999
15,184
M&T:
I think you boat had an Isomat spar. Rig-rite has these parts. The gate for the slugs was made from metal and there was a thumb screw that kept it in place.
www.rigrite.com
Dec 2, 1999
15,184
NG-105 Mast – Mainsail GatesNG2 Mainsail Gate & Screw Kit: NG2-9K:
Cast aluminum Mainsail Gate fits NG-60 through NG-105 Mast Sections. Gate has horizontal slot for Thumbscrew (NGA-10); Gate is 'opened' by loosening Thumbscrew and sliding gate away from Mainsail track. Kit includes Gate casting, NG2-9, and SS Thumbscrew, NGA-10.
NG2 Mainsail Gate: NG2-9:
Cast aluminum Mainsail Gate fits NG-60 through NG-105 Mast Sections. Gate casting is 2 3/8" (60mm) high x 1 7/16" (36mm) wide, with 1/4" (7mm) deep lip. Part is labeled #157007.
NG2 Mainsail Gate Screw: NGA-10:
SS Thumbscrew is 4mm diameter with 5/8" (15mm) long thread and has serrated plastic head.
