E
Ernie Scott
I'd like to modify my 1985 H28.5 to lead all lines to the cockpit. Has anyone added a deck organizer (line control sheaves) to the raised deck portion that is apparently molded in the deck to accomodate hardware? How do you mount at this location? Is there an embedded backing plate? Do you have to drill and tap?Also, to run reefing and outhaul lines aft additional blocks are needed at the mast base. Anyone figured an easy and secure way to mount blocks at this location?
