H28.5 '85 Rudder play/adjustment
Rick
Oct 5, 2004
1,098
Hunter 420 Passage San Diego
I have some slight play in the rudder, and a noticeable "squeak" when secured at the dock and the wheel lock engaged. Otherwise, rudder operates OK at sea. Would like some info/how-to on checking for adjustment/tightening of rudder control mechanism. Thanks in advance...
C
Craig Shaw
rudder adj.
Rick I just did my 1985 28.5 Center the rudder and lock the wheel Then climb down and check and see if ther is play in the rudder. If there is pull the cooler in the starbord rear and you can see the cabels takes a 9/16 wrench and adjust the slop. Good luck Craig
