H27 Rudder Replacement
15
Catalina 30 Tall rig Punta Gorda FL
I want to replace a leaking rudder on my wheel steering 1980 H27. It is on a lift so no problem that way. Foss Foam makes replacement. Problem is I can't free up the cable wheel assembly on the rudder shaft. Thinking of sawzall to cut rudder shaft in sections to allow removal. Any other ideas out there?
H
HN
Old Faithful ATricks from Grandpa
Liquid Wrench or WD 40 sprayed every day or so for a week. If that doesn't do it, a little heat from a plumbers torch to the bolts and may work. (Keep a bucket of water near in case)
