The sliding door between the saloon and the head will not close all the way because the port side of the ceiling has dropped about 1/2" when compared to the starboard side. Not sure how to go about doing a permanent fix because I don't how the mast/compression post area is constructed on the 27. The compression area on the bottom of the post is a mystery also. I've seen some pics of the H30 where you can see an iron support plate under the post from the bilge. Can any shed some light on the H27 construction?
