David Foster
Although Lady Lillie's survey said the mast step was OK, I have read about issues with the compression post, and decided to check it out while the mast is down before launching next month. She is a '77 h27 with a shoal draft keel.What I found was this:Two 1 inch teak boards form a T roughly under the mast step. The top of the T is the back side of the slot for the sliding door. Is this the compression post?The boards end on the fiberglass floor of the cabin. This is quarter inch solid fiberglass mounted on what looks like glassed in 2x4's shaped to the bilge underneath. The boards (compression post?) rest on the floor about halfway between two of the 2x4's.Is this the standard set-up? Is all the mast compression (I'm running 400-550 pounds per stay) supported on the quarter inch floor? Or is some of the load carried by the arch of the cabin roof?I'm not worried, because everything is sound and worked fine through last summer, but now I'm really curious, and hoping for some insight!!
