Yes, that's what I'm referring to. I didn't realize it was called a different name.I think what you're referring to is a "bowsprit", which sticks out in front of the bow.
I installed a bow anchor roller to my H27 to handle my new Rocna 10kg. It was a tight fit around the roller furler but has worked out nicely. The anchor roller channel extends a little aft of the cleat, so I installed another cleat in the bottom of the anchor locker so that there is a straight run through the anchor roller channel. The anchor roller is thru bolted so access to the backing plate, nuts and washers was a challenge, but doable. Here is a pic:Has anyone ever added a bow pulpit to their H27, or other Cherubini? I'd like to add one to mine to carry a slightly oversized Mantus anchor.
