Water Pump Connection
There are a lot of great things about the H260, but the hand pump water faucets are not one of them. The faucets that come with the boat never worked for me and the quick disconnect fittings leaked. In addition, there is no easy way to empty or clean the water tank - as a result, algae builds up in the system and the water gets stale. You have the right idea, but you'll have to enlarge the hole and make sure the splices don't leak. I first installed the Finspray faucets but still had problems with leaks - decided to start over. Using the experience of others, I installed a pressurized water system. This involved replacing the water lines, installing a pump and inline filters, new faucets and adding an access hole to the tank. I got all the fittings and tubing from Home depot and the shurflow pump and faucets from West Marine. The whole project went together in a day. Go to: http://kobernus.com/hunter260/water/water.html
