vhf 260
On the starboard side of mast, drill a hole for a two inch double ended female fitting you can get from the HOw chandlrey or West Marine. Make sure you drill just enough for it to go thru. At that point, install using 5200. This is your quick release for the vhf wiring when you dis mast. Take off the panels around the compression post inside on the ceiling. YOu should see a blue tube. Generally it will go all the way back to the electrical panel minus 6 inches from it but you will not be able to see it if you take the panel off adjacent to the electical panel.. Run a snake with a messenger line. That is how to feed the coaxil cable. good luck.One other thing about VHF radios with the emergency beacon. Do not play around with that button because if it is activated without an emergency, you will be up Fiddlesticks creek without a paddle with the coast gaurd. With that, you can add nema wiring from your GPS so that if it is activated, the actual coordinates will also be sent as well. an example is the ICOM 402 VHF. Be sure your GPS does have the Nema capability if you are thinking of this.
