When my H260 was delivered, the rear mast crutch pole had a significant bend in it where the upper crutch hole was at the stern. As a result, the crutch contacts the mast where the shrouds attach to the upper part of the mast. My dealer says this bend in the pole itself is normal. I agree that the way the crutch holes are aligned puts the crutch pole at an angle to the mast, but what is the purpose of the bend in the pole itself? I believe this bend in the pole was caused by the dealer dragging the mast across the crutch causing the bend in the pole. I've added a roller to the crutch and the mast now slides much easier when raising and lowering the mast. I still don't think this bend is intended by Hunter. Any thoughts? How do I get in touch with the proper person at Hunter?
