H260 Gray Port replacement Lense ( 1999)
LarryH
May 5, 2010
38
Hunter 260 Palm Beach County
Does anyone know the part number for the proper lense to replace? Also, i cant figure out to take the old lense off, i dont see any release.
Thanks,
Larry
Dec 2, 1999
15,184
Larry:
If I remember there are pins in the hinge that need to be knocked out. I have never done this so I would not have any advise other than be careful so you do not break them.
I assume that yours are fogged up? If that is the case, I would suggest that you try brasso on them (you will be amazed). If you have broken parts on the lens where they dog down, that is another issue and they will need to be replaced.
Phil Herring
Alien
Mar 25, 1997
4,924
- - Bainbridge Island
If you need to replace it give us a call on Monday, we can help with that. 1-877-932-7245
Feb 8, 2008
93
Hunter. 260 Farr 40.7 Albany-
I need a new gasket/seal
The rubber seal on the opening port light on the starboard side (above the cooktop) of my 260 is broken.
Can I buy a couple??
Mark
