Hunter 260 Bow Roller
I found an anchor bow roller that fits perfectly. I purchased a WINDLINE # AR-3 model. It measures 11" long and 13/4' wide. It Handles up to 1" line. The West Marine Catalog # is 153593. It fits neatly into the opening on the starboard side of the anchor box.NOTE. If your going to install a bow roller yourself make sure you take your time drilling through the gel coat layer. In this area on a Hunter 260 you will be required to drill and "tap" through a metal plate. Just make sure you drill a smaller hole than required and then "Tap" through the the metal plate with the size tap required. My bow roller required three # 3/8" bolts. Also, prior to drilling the holes make sure the rode and anchor line miss (don't rub) the rub rail on the boat. Oh yea, the most important part....This bow roller cost $69.99 in the West Marine catalog.If you require any additional information relating to the Hunter 260 you can contact me at java@apci.net.Safe Anchoring, Wayne
