H260: A different traveler design possible?
178
Catalina 25 The mountains
I wondered if there is any way to reinforce the deck to accomplish this.
I've seen travelers mounted at the companion way and always thought that small traveler probably isn't that helpful except for moving where the mainsheet attaches.
I saw a boat (not a hunter) with a traveler design that arches over the companion way. It would give a nice long traveler, moves the mainsheet away from the cockpit, and still allows you to pop up the companion way lid.
The only problem is whether or not the deck is strong enough and if it's possible to reinforce it.
Here's my questionable rendering. Your thoughts?
130
Seaward 24 Indianapolis
To have a traveler and the companionway "lift up" operational your arch would need to be around 4 foot from the mast base. I'm not sure you gain anything in performance by having it that far forward. You could always cut a new access panel in the headliner and add backing plates to through bolt if you go this way.
I like the mainsheet in the cockpit
Jun 16, 2010
495
In search of my next boat Palm Harbor, FL
Not saying that you can or can't do it, but moving your traveller forward, also may mean moving your attachment to the boom forward. Some people like mid boom sheeting, some don't - i am sure that will spurn a conversation in its self.
-na -NA Anywhere USA
I have seen a travelers added just in front of the entrance to the companionway which is about the only place. What ever you do, you will be thru bolting and make sure you use alot of sealant. You would of course need to check inside that the area udnderneath where the bolts would come out of the cabin ceiling that it is solid. Otherwise you would probably have to shoot some expanding foam between the ceiling and deck to make it stiff. Also you would need to have large washers under the nuts to spread the load. There is anther way of attaching the bolts but to be frank, I never found the need to have a traveler. Alot is in sail control which eleminates the need for a traveler on this boat.
Boy I bet there will be a long thread over my last comment. It is just one opinion.
crazy dave condon
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
Sail Control??
I have a "mini-traveler" in front of the entrance to the companionway of my H-26, the main use I have for it is to be able to slide the main sheet tackle over for easier entrance into the cabin. It also serves to free up some cockpit space as an alternate attachment point. I had no idea some folks use it for sail control, I'll have to give it a try! :dance::D Frankly, I COULD probably use it to squeeze out a tiny bit more performance, but I'm not that kind of sailor. BrianW
Aug 10, 2010
178
I've been studying sail trim quite a bit as of late and the traveler can help you to dump a gust without messing up your sail trim. It can also help you with twist which can be used to reduce heel or to take out twist to get more power out of the main.
But a traveler the size that fits at the bottom of the companion way isn't really long enough to help much for that type of use.
May 25, 2004
981
Catalina Capri 14.2 1670 Rochester, MN
Block and tackle
I have a simple solution that requires no alterations. When I need to pull the boom closer to the center line without pulling down, I simply attach a block and tackle to the end of the boom and then attach the other end to the top of a life line stanchion on the windward side.
When I tack, the "traveler" goes slack. Once my course is set, I move the block to the windward side again.
This way I have a traveler when conditions require flattening sail, but I have no hardware in the way the rest of the time. This same block and tackle doubles as my preventer when I running downwind.
Cephius;
I replaced stanchions and repaired stern pulpits on several boats with folks using your attachment when used in strong winds. I urge caution in that use in strong winds. Food for thought.
May 25, 2004
981
Thanks Crazy Dave. I go home when winds get to damaging levels :)
When it comes to Class C boats, I'm a fair weather sailor.
Thank you for being kind to me and realizing what I said. You take care of your boat while others don't. Have fun sailing.
The worst is getting caught in a hurricane off shore and once was enuf.
Crazy dave condon
suds
Nov 16, 2010
36
N/A N/A N/A
My traveler is located on on the stern, which is an ideal location. The only problem I see with this design is the bimini.
183
Catalina 1990 Catalina 30 Mark II Harbor Island Yacht Club, Old Hickory Lake, Nashville, TN
That's where it is on a Catalina 30.
Bob
May 25, 2004
981
On the H260 the boom ends in the middle of the cockpit, about 4 feet from the stern. If you lead the main sheet aft to a traveler, the sever angle of the sheet would make any adjustment on the traveler ineffective.
This doesn't even consider that the sheet would be going through the helm on H260s with that option and the traveler would be on the helm seat. Less then ideal.
When the Capri 22 was introduced, the traveler was right in the middle of the cockpit, spanning the seats, and the crew had to climb over it. I guess with "sport" boats sail control is more important than crew comfort.
If you were to add a traveler at the current sheet location on the H260, you would get the same results, splitting the cockpit. The traveler would be long enough to make significant main sail shape changes. One big difference between the Capri 22 and the H260 is seat height. This would be a major impermanent to us older sailors with bad knees on the H260.
suds
Nov 16, 2010
36
N/A N/A N/A
My Hunter 25 is a masthead rig sloop and the boom sheet is at the aft of the helm.
I'm guessing the Hunter 260 is a fractional
May 17, 2010
81
Hunter 270 Ottawa
Cockpit SS Arch
The only feasible way of putting an effective traveler on a Hunter 260 without `splitting` the cockpit would be to put on a stainless steel arch like the big Hunters have. I have a 2002 Hunter 270 with a small traveler at the companionway. This traveler does have a positive effect on mainsail trim & I use a block & tackle from the mid boom attachment to the bases of the cabin top stanchions to compensate for the short length of the traveler.
The Hunter 260 was designed for trailering. Adding an arch, yu might as well as forget trailering as it would be most difficult getting the mast down. Then you have to worry about the added height when trailering not to mention the cost. These are reasons why no traveler was availble from Hunter
May 17, 2010
81
Hunter 270 Ottawa
Detachable Traveler
I do not trailer my 2002 Hunter 270, so the SS Arch idea apppeals but the cost & difficulty of ensuring a strong attachment to the coaming when it was not designed with an arch in mind, have kept it at the "idea" level so far.
Another alternative would be to put a detachable traveler that would go from coaming to coaming on the seating area, just above the small companionway traveler now installed. I have seen ads for large sailboats that promoted detachable travelers that could be removed to facilitate socializing etc in the cockpit when not sailing. I would not be able to use the detachable traveler when sailing with my wife as she would not put up with climbing over it to get into the cabin etc. and has no intention of altering the cockpit cushions for such an arrangement.
