H26 Trailer Tires
Rich & Lynn Clough
I bought a used 1996 Hunter H26 Water Ballast and need new tires for its twin axle, Hunter Trailer. The tires on it, which I assume are original, are Carlisle nylon cord ( tread - 2 ply nylon cord, sidewalls - 2 ply nylon cord, Load Range C ). I can find nothing but radials. Does anyone have any comments on radials vs cord or bias ply.
Rick Webb
Try These Guys
They are really sharp and very happy to answer any questions.
T J Furstenau
Been there, done that.
I just had to replace the the tires on my trailer and went through the some issue. The advice I got was that the bias ply have a stiffer sidewall and will tow better/smoother with less sway, hence the reason most trailers use them. Although they do tend to run hotter than radials. The advice I give is check around with some of the smaller tire dealers around, not the Goodyear/Firestone dealers. The dealer I went to didn't carry them, but ordered them and had them in in 2-3 days. On a side note, my spare is a radial, as I had a tire throw its tread on a trip, and all I could replace it with was a radial. I didn't want to throw it away, cause it's like new, but I don't recommend mixing bias/radials. T J
H
Harvey Small
Boat Stores
I had a flat and decided to get a spare wheel & tire for my H-26 trailer. My local yard, St Louis Sailing had a mounted tire, and West Marine and Bass Pro shop also have tires and wheels on their websites. You might try Boat US also. Good luck
