H26 Sail Slide
162
Hunter 26 0 Boca Chica, Rep. of Panama
What the specs for the sail slide on the main sail
I'm trying to order replacements and I'm not sure what size to get.
I brought one back from the boat that is broken ( 2hrs away) and I'm not absolutely sure I can match it to the specs I find on product retailer websites.
The one I need to replace ( and want to buy spares ) is one that clips on to the main sail. It's not sewn into the sail like some other on my main sail. The clip and the slide are nylon/plastic. The product websites want the dimensions of the slide. Since the one I brought back with me as a broken off slide I'm not sure I can pick out the right ones to get.
I have a 1996 H26. I just purchased it. I'm located in the Rep. of Panama and I can just walk into a sail shop because are none to speak of. I need to order from the US.
thank you
Apr 10, 2010
162
correction: "I can not just walk into a sail shop............
Apr 10, 2010
162
I sent them a message describing the part. I didn't see sail slides listed on their web page
thanks for the reply
May 25, 2004
981
Catalina Capri 14.2 1670 Rochester, MN
Sail Slug
Since you have one with you, just measure the part that slides up the mast slot.
You can order one on-line from your favorite retailer.
Either of the slides listed on this page will work. I prefer the one with the metal bail. slug link
The shackle that holds the slug to the sail is also available. Here is one style:
shackle link
Apr 10, 2010
162
ah but the slug is broken off..
"slug" a good description.
guess I'll just have to cruise on out to the coast again and get the measurement of the slug. Had hoped that a H26 owner would spot this
thanks
