H26 On Boat Stands
Jun 2, 2004
3,672
Another Thought
Not sure what the clearance is between the bracket and the nut but a couple pieces of flat aluminum stock jammed in there on either side may just do the trick.
I am thinking you will need to do both sides as the bolt comes loose and starts to wobble.
DJN51
Oct 26, 2009
377
Hunter 23.5 East Chicago In
On my 23.5 I drilled the bolt head off.and the bracket went down with keel.Actually easier then I thought it would be .Nut weld did break.ground it down had new nut welded,worked great
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
After trying unsuccessfully to grind and later using a Dremel tool to remove the bolt head, I decided to drill off the bolt head. The main obstacle was the head is recessed in a "well" and it was difficult to access at the proper angles for my grinder and Dremel tool. I then turned to drilling it out with cobalt drill bits. Very slow drilling while applying lubricant. At one point, to keep the whole bolt from spinning, I applied a flat pry bar in the tiny space under the bolt head and pried upward. It kept the bolt from spinning up to a point. Then, the whole bolt began very rapid spinning, while I was applying strong upward force. Suddenly, I heard a "clunk" and the WHOLE bolt popped out of the hole! I guess the upward pressure jammed the nut firmly enough to unscrew it! The expression is true!! "Even a blind hog finds a nut every now and then"! BrianW
BrianW
Jan 7, 2005
843
DJN51 and Rick Webb, it seems BOTH of your ideas worked at the same time!! BrianW
