Hi All: When raising the mast of my '94 H26, the hole at the base of the mast to accept the mast raising pole bent inward at the bottom and outward at the top. The mast definitely wasn't bound in any way. I was able to manually lift the mast a foot or so from the mast crutch pole. Fortunately, I was able to find a scrap H26 mast and cut a 6" section from it to make a reinforcing sleeve around the lower section of my mast and made a new hole to accept the mast raising pole. Now when I raise the mast I manually assist the mast lift for the first few feet of the lift. What happenened to cause the initial damage? Has anyone experienced this? Any solutions? Thanks, BrianW
