H26 Jib Sheet Cleating Options
Fred
Sep 27, 2008
517
Catalina 28 mkii 745 Ottawa, Ontario, CA
I sail a 1995 H26 (new to me this year) and am looking for options that would allow me to more easily single hand. I find the stock cleating arrangement for the jib sheets very awkward (winch & horn cleat) and would like to come up with a better arrangement that would allow for easy adjustment and release.
Are there other arrangements out there? What are others doing?
May 25, 2004
958
Hunter 260 Pepin, WI
Fred,
It sounds like the H26 has a better arrangement than the H260. We have a clam cleat forward of the winch, with the clams engaging in a forward motion. Awkward.
I have attached very long jib sheets that allow me to handle them from just forwared of the helm station. This allows me to control the sheets druning a tack. I still need to step up to the cabin to cleat the leeward sheet after the tack.
Jun 6, 2006
6,990
how about adding tailers to the winches? If you don't use the winches much for the jib just wrap it once around the drum and pull from there, no need to use the crank handle for light loads. Then "cleating" the sheet is just a matter of running it through the tailer.
FWIW
