Have any of you H 26 owners had experience with metal deterioration of of the s.s. mechanism that raises and lowers the centerboard? I have sailed my H 26, "Molly," in the Bay of Banderas, Mexico, for 10 years +. She has been in the water (salt water, of course) for all that time. I had the s.s. mechanism examined several years ago, during a bi-annual haulout. No problem. I keep a wire inside the boat that connects the mast base (that is in direct contact with the raising/lowering system) with the wing nut that raised/lowers the valve that drains the ballast tank, and continue the wire overboard to a small zinc that I keep in the water at all times except when sailing. This zinc does deteriorate. I check its conductivity with the valve and centerboard regularly. I replace the zinc about twice a year. I'll make a visual centerboard check during my next haulout. But still, it gives one a couse for concern by not having a visual check in many years. The ballast tank valve, which I can easily check during haulout, is always fine. By the way, no blisters.
David K "Molly"
David K "Molly"
