In Pensacola, FL lately, I've had to haul out (trailer) my H26 fairly frequently because of many many many storms this year. I normally keep the boat in a slip. Each time I pull it out, it may be out of the water for a week to a month. The bottom paint oxidizes quite a bit in this period. The fiberglass portion of the rudder has been painted with bottom paint. When in the slip, I keep the rudder out of the water. Several questions. What bottom paint will be most effective for having a boat in salt water most of the time, but out of the water several times a year? What type of paint should be on the rudder if it is raised up when not sailing? What is the best and easiest way to remove oxidized paint after a haulout? Thanks! BrianW
