Well, I had the 26.5 out in "building conditions" today. I reefed the main early, then progressively reefed the jib in 3 different steps, each about an hour apart. By the time I came back into the inlet, it was certainly blowing over 25. Even the ICW was full of whitecaps. At 25 knots, that boat would benefit from a second set of reefing points in the main. The roller reefing on the jib worked well.
All in all, the little 26.5 did pretty well. Weather helm got a little heavy once the jib was less than half out, but that was to be expected. I just had one little unpleasant surprise. The forward cabin had 3 distinct spray patterns on the cushions where water came in, apparently under force. The bilge had about 8 oz of water in it. It looks like I probably have a few small holes around the rub rail on the port side that get water forced into them when the bow comes down in heavy seas. I'm thinking that someone probably replaced the rub rail at some point in the past & didn't plug all the old screw holes correctly, but I will need to dig in a little deeper when the weather calms down a bit.
