H25 Electrical
68
Hunter 25 Chicago
I have been searching and searching for electrical ideas for my 1978 Hunter 25. Currently, I have just a single battery and an old Johnson 15hp outboard. I would like to upgrade the outboard to a new 4 stroke 15hp. But more importantly I need to revamp the electrical system.
I would like to add 2 more batteries or just 2 big batteries to run the whole boat. I know the output of the little outboard most likely wouldn't be enough to properly charge and manage the two batteries. A shore power plug, and a charger is where I start to get stuck. From there, I need to add a stereo and tie in the lights (all LED), vhf, and bilge pump. Any ideas for a basic system that would work? How would I properly ground a system like this where our boat has no zinc?
Thanks everyone.
Grounding for outboard powered boats is the negative of the battery bank.
A four stroke outboard is gonna be waaay heavier. Most 25 foot boats can do with 9.9 hp outboards. Ours did fine (C25) with a 7.5 hp here on SF Bay.
Electrical: adding batteries is easy. Try the West Marine Advisors: http://www.westmarine.com/webapp/wc...01&page=Batteries-Second-Battery#.UUupwVdXr-I
Those advisors also have more articles that may answer your questions.
Adding a stereo is easy, just wire it up based on the instructions in the stereo manual. Your choice whether you want or need to have the memory on all the time.
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
At this point I have redone nearly everything about the electrical system on my H27, dig through my website (link is below) you should find lots of ideas. Btw, I opted to forego any shore power, and just charge from solar and the outboard engine. Have been quite pleased!
