After reviewing the Hunter manual drawings I examined my rudder and the controls are different. I assume that the manual reflects changes made on later models due to the difficulty of raising the rudder when is is flooded. The manual shows a movable block in the control line for pulling the rudder down (inside the rudder post). Getting it down is not an issue getting it up is (no pun intended). I intend to modify my rudder arrangement to reflect the added block on the lifting side. I plan to disconnect the line from the knotted hole in the back of the rudder, pull it out of the rudder post and add second hole lower than the existing hole which is too high to incorporate the new scheme.
Is there any issue with drilling a new hole through the rudder to add a three foot loop to a new block? I found where someone else had made this modification and posted it but he did not mention have to drill a new hole in the rudder.
