H240 main battery fuse missing
Feb 18, 2011
341
Hunter 260 Cave Run Lake, KY
While doing some electrical work on my '98 H240 I noticed there is no main fuse on the battery- I checked the positive wire as far as it was exposed, including inside the flexible plastic conduit. The wiring diagram in the manual indicates a 40 amp fuse should be there- and my battery location and wiring appear original. I plan to add a terminal fuse block (Blue Seas 5191), but was wondering if other 240's were missing this safety device? Will probably go with a 40 amp fuse, but considering dropping to 30 amp due to my limited electric load.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
what ever fuse you decide on try hard to fuse it within 7 to 9 inches from the battery post ....if your wire size calls for a 40 amp fuse do that but don't up size the fuse
-na -NA Anywhere USA
caverun;
It has been some time but there should be an inline fuse holder with a 40 amp fuse in it. I found if you look at the wire from the battery going backward on the red wire you should find it stuck behind the cockpit seating possibly in the foam.
